deenn
Jun 22, 2021Tutor
Orbi + PiHole DNS problem
Hey everyone, After having to reset my Orbi router this morning after all my late night tinkering yesterday, i've come to you for help. I've installed PiHole on a fresh pi 3B+ and i can reach it...
Jun 22, 2021Guru - Experienced User
I've used pihole on my orbi before and it worked well.
but I wasn't cascading routers. i was going direct modem only device to orbi.
It could be the ISP modem is acting in some factor.
What modem/gateway is it?
Are you using ipv4/ipv6?
Where are you plugging your info into (screen shot it)?
Have you tried using the isp device as the router (disable its wifi) and use the orbi as an access point? Might simplify the DNS setup.
