JasonShel
Dec 31, 2016Follower
Orbi / Security Panel
I just bout and Orbi router and satellite. I am not the most technical but can usually find my way around. I have a COR security system that will easily connect to my existing routers. For some re...
rhester72
Dec 31, 2016Virtuoso
Some security systems require a static IP address and port forward for them to work properly. Check with your security system provider.
Rodney
