JenEricRal
Oct 22, 2018Guide
Orbi & the new Roomba i7+ connectivity
(I apologize for the repost. There was some sort of techinical error with my original post.) We recently purchased a Roomba i7+. We could not get it to connect to Roomba's servers to update it's s...
- Oct 22, 2018
Yes if you had a modem/router combo before and it wasn't bridged, the Orbi will re-configure for 10. address pool. Since you have the newer SB series modem only, I presume you haven't every reset the Orbi thus keeping the 10 address pool. This is fine. It could be possible that maybe if you have not done a reset on the Orbi since, then maybe you can do this as a last resort.
Yes you set up the DMZ for the 3700 correctly. I was hoping this would help avoid any issues between the Orbi and Roomba however someting seems to be keeping the Roomba from fully connecting. It's possible there is some port issue or someting on Orbi thats stopping it.
Yes you'll see other wired devices on the 3700 as it's connected client app is searching was connected to it's LAN port thus seeing other devices stemming from the Orbi thru the 3700. This is expected.
If you decide to do the factory reset on the Orbi, go ahead and turn OFF the 3700 and Roomba for now. Set up the Orbi router from scratch, walk thru the setup wizard. This time you'll get a 192.168.1.1 on the router, You might first test the Roomba to see if it connects thru the router first. Then try setting WPA to disable temporarily. If the Roomba still does not connect fully with WPA disabled and it's services don't appear, then Roomba and NG need to review this and hopefully collaborate and find a fix. Be sure to re-enable WPA2 and AES after testing the Roomba.
Oct 22, 2018Guru - Experienced User
Try this, set up Guest network on the Orib and see if the Roomba will connect here...
Try the 3700 LAN to LAN connected to the Orbi. Ensure that the 3700 is configured for AP mode fully, I don't remember if the 3700 had a web page AP option or not. You can manually set AP mode by setting a new IP address for the routers IP address from 192.168.1.1 to .1.37. Turn OFF items such as uPnP, Firewall, Guest Network Wifi and any Traffic or QoS features. Configure the SSID on the 3700 for something different and make sure the channels between the Orbi and 3700 are far from each other, they can't be on the same channe. When these are all disabled, disable DHCP server at the very last. Save settings. Then connect the 3700 LAN port to a open LAN port on the Orbi. You should be able to access the 3700 web page at 192.168.1.37 from the Orbi side of it's LAN port with a wired PC.
- JenEricRalOct 22, 2018Guide
Thank you for your help. I believe many things I have tried have come from reading your posts in my search. :) I DID try setting up a guest network on the Orbi and connectng to that. (It did not work.) Add that to the list of things I have tried. lol
I will try the other stuff with my 3700 and get back to you.- Retired_MemberOct 22, 2018
have you seen this:
- FURRYe38Oct 22, 2018Guru - Experienced User
Ok, keep us posted. I'm hoping the 3700 method will work. You may still need to put it's IP address into the Orbi DMZ as well.
You can try separating the wifi SSIDs on the Orbi however I don't recommend it as this defeats the Orbi MESH design and purpose. So this is why I suggested the use of the 3700 as an entry point for the Roomba...
You could possibly reach out to those who have been successful in seperating the freqs. The question would be did it affect overall performance of the Orbi?,..... as opposed to labeling it a defeatist effort.
I am going to describe what I did, and hopefully you can tell me if I did it correctly. I am far from great at this stuff, so I rely on online tutorials.
-I already had different SSID's set up for both routers. I ensured all were on different channels.
-In Orbi, under Advanced>Setup>LAN setup, I changed the Starting and Ending IP address range from 10.0.0.2-10.0.0.254 to 10.0.0.2-10.0.0.250, because something I read said to manually set up an AP, you had to give the AP router an IP address within the same subnet, but outside of the DHCP range of the main router.
-on the 3700, under Advanced>LAN Setup, I entered 10.0.0.254. I turned off UPnP, then I unchecked "Use Router as DHCP Server."
-I then connected a LAN port on the Orbi to a LAN port on the 3700.
What I am seeing now:
-I can successfully connect to the 3700's SSID's, with a working internet connection. I connected my phone and the Roomba to it.-My phone and the Roomba are connected to the 3700's SSID, but in the Roomba app and on my phone, they show they are connected to Orbi's IP address.
-In Orbi under attached devices, the 3700, the Roomba and my phone are all showing up as WIRED devices connected to the Orbi Router.
The issue with my Roomba still exists.Let me know if I did something incorrectly.
Yes great work on the 3700. you have it working.
Odd though that the Orbi is using 10. address scheme though, default is 192.168.1...Well if it's working don't bother this.
Lets try adding the IP address for the 3700 in to the Orbi routers DMZ and save settings, reboot the router and 3700 and Roombas.
Devices that are connected to the 3700 will show up as wired devices since the 3700 is actually a wired device connected to the Orbi router, so this is expected and ok.
Hoping this will help. I would recommend that you contact the Mfr of Roomba and give them this thread and see if they have any input. If ALL others devices connect and working with the Orbi and the Roomba is the only device having problems, Both Rooma and NG will need to have a review of this.
Thanks for confirming that I did the AP setup correctly.
The Orbi's IP as always been 10 for us. We have owned our fair share of routers, and it is a first for us. Back when we first got it, we used it with an modem/router combo from AT&T (fiber network.) Originally, we did not have the AT&T's router disabled. Maybe that has something to do with it? No clue! (We are currently using Cox's Gigablast service in a new state, as we had moved.)
Did I do this correctly? I went to ADVANCED>Setup>WAN Setup, clicked "Enable Default DMZ Server," and then entered the 3700's IP address. Then I reset everything. The issue still persists. Even if it did work, what kind of security risk is there for having the 3700 in the Orbi's DMZ?In the 3700's attached devices list, there are 9 devices now showing on the WIRED list, and then my phone and the Roomba in the Wireless.The Orbi Router and the two satellites are 3 of the 9 devices on the wired list. (Some were showing before I made the DMZ change.)
I have been in touch with iRobot's support for a few weeks now. Over the weekend, I sent them a message letting them know that the 3700 worked, so that means there is an issue between Orbi and Roomba. They just responded suggesting that I check for a firmware update on the Orbi. That was one of the first things I had tried. :smileylol: I will go ahead and link them with this thread, too.
Thank you so much for your help on this. I really appreciate it!
