JenEricRal
Oct 22, 2018Guide
Orbi & the new Roomba i7+ connectivity
(I apologize for the repost. There was some sort of techinical error with my original post.) We recently purchased a Roomba i7+. We could not get it to connect to Roomba's servers to update it's s...
- Oct 22, 2018
Yes if you had a modem/router combo before and it wasn't bridged, the Orbi will re-configure for 10. address pool. Since you have the newer SB series modem only, I presume you haven't every reset the Orbi thus keeping the 10 address pool. This is fine. It could be possible that maybe if you have not done a reset on the Orbi since, then maybe you can do this as a last resort.
Yes you set up the DMZ for the 3700 correctly. I was hoping this would help avoid any issues between the Orbi and Roomba however someting seems to be keeping the Roomba from fully connecting. It's possible there is some port issue or someting on Orbi thats stopping it.
Yes you'll see other wired devices on the 3700 as it's connected client app is searching was connected to it's LAN port thus seeing other devices stemming from the Orbi thru the 3700. This is expected.
If you decide to do the factory reset on the Orbi, go ahead and turn OFF the 3700 and Roomba for now. Set up the Orbi router from scratch, walk thru the setup wizard. This time you'll get a 192.168.1.1 on the router, You might first test the Roomba to see if it connects thru the router first. Then try setting WPA to disable temporarily. If the Roomba still does not connect fully with WPA disabled and it's services don't appear, then Roomba and NG need to review this and hopefully collaborate and find a fix. Be sure to re-enable WPA2 and AES after testing the Roomba.
JenEricRal
Oct 22, 2018Guide
Thanks for confirming that I did the AP setup correctly.
The Orbi's IP as always been 10 for us. We have owned our fair share of routers, and it is a first for us. Back when we first got it, we used it with an modem/router combo from AT&T (fiber network.) Originally, we did not have the AT&T's router disabled. Maybe that has something to do with it? No clue! (We are currently using Cox's Gigablast service in a new state, as we had moved.)
Did I do this correctly? I went to ADVANCED>Setup>WAN Setup, clicked "Enable Default DMZ Server," and then entered the 3700's IP address. Then I reset everything. The issue still persists. Even if it did work, what kind of security risk is there for having the 3700 in the Orbi's DMZ?
In the 3700's attached devices list, there are 9 devices now showing on the WIRED list, and then my phone and the Roomba in the Wireless.The Orbi Router and the two satellites are 3 of the 9 devices on the wired list. (Some were showing before I made the DMZ change.)
I have been in touch with iRobot's support for a few weeks now. Over the weekend, I sent them a message letting them know that the 3700 worked, so that means there is an issue between Orbi and Roomba. They just responded suggesting that I check for a firmware update on the Orbi. That was one of the first things I had tried. :smileylol: I will go ahead and link them with this thread, too.
Thank you so much for your help on this. I really appreciate it!
FURRYe38 wrote:
Yes great work on the 3700. you have it working.
Odd though that the Orbi is using 10. address scheme though, default is 192.168.1...Well if it's working don't bother this.
Lets try adding the IP address for the 3700 in to the Orbi routers DMZ and save settings, reboot the router and 3700 and Roombas.
Devices that are connected to the 3700 will show up as wired devices since the 3700 is actually a wired device connected to the Orbi router, so this is expected and ok.
Hoping this will help. I would recommend that you contact the Mfr of Roomba and give them this thread and see if they have any input. If ALL others devices connect and working with the Orbi and the Roomba is the only device having problems, Both Rooma and NG will need to have a review of this.
Oct 22, 2018Guru - Experienced User
- JenEricRalOct 22, 2018Guide
That makes sense. No, we didn't do any sort of factory reset on the Orbi when we moved, or after I had figured out that having two routers was causing our double NAT. I do like the 10's for its simplistic look, though. lol Are there any disadvantages to the 10's? If I do do a factory reset and it gives me the ol' 192, can I manually switch it back to 10's if I want? :smileylol:
It is sounding like a full reset may be necessary. I don't think it should be too big of a deal other than having to rename a few things. UPnP has been working pretty well, for the most part, so we don't even have anything port forwarded anymore.- FURRYe38Oct 22, 2018Guru - Experienced User
Yes, if you still like using 10, you can certainly keep it.
You might change the pool size to 100. to .200. Give you a bit more room for static IP addresses on either side.
Yes, uPnP is working well and you don't need PF when it's enabled.
Let us know how it goes with a reset and check the roomba. Worth a try. :smileyfrustrated:
You Rock!!! Thank you so much for taking the time to help me out. The factory reset worked, THANK GOODNESS!!!
Unless I missed something, all the settings were the same after the reset except for Daisy Chain and IPv6. Daisy Chain was turned on, and IPv6 was turned off. I had toggled the Daisy Chain on and off while troubleshooting, but never turned off IPv6. I successfully turned IPv6 back on and all still works fine. I'm pretty curious what caused the issue, but I am so glad it is working now.
Oh, and my husband was the one that switched the network to 10. when we bought the Orbi. He said it is more secure. I did set up the new network with 10 because it is prettier than 192. :smileytongue:
- FURRYe38Oct 23, 2018Guru - Experienced User
Great to hear. Glad its working.
Ya there may have been some hold over settings from prior use of the other ISP modem which could still have been in the router configuration. I've noticed that when switching ISP modems, the Orbi seems to hold on to some of these settings for unknown reasons, and the only way to get them blown out is to factory reset. Well if you tried daisy chain and IPv6 and Roomba is still working, I presume it may not be something related to those.
Thats funny. 10 is not more secure than any other IP address. You can use 10, 172 or 192 or any class C address schema. However asthetics and looks is everything. LOL. :smileytongue:
Enjoy. :smileywink:
- wischmi2Nov 10, 2018Aspirant
I'm sorry, I don't understand what the solution is. We have the same issue. We have the Orbi system setup and we have the i7+ and can't get any of the cloud functions to work. Could someone add another post that does a step by step solution?
Also, did I read correctly that the roomba will work on the 5GHz network?
Thanks.
