LEWB71
Aug 28, 2020Aspirant
Orbi & Verizon Fios Internet Only
I have Verizon Fios Internet, cable & phone. I want to drop cable TV and phone. I have the fiber optic cable coming into the Verizon box outside and it changes over to coax that comes to the Fios Quantum router. Currently, ORBI is operating in AP mode. I want to get rid of the TV, phone and the Verizon Quantum router. I want to use only the ORBI RBR 50 and satellite router. I know ORBI does not contain a MOCA adapter inside. However, since the signal is coming in as a “internet” signal, do I need to attach a MOCA adapter to the ORBI and satellite?
- MstrbigMaster
LEWB71 wrote:
I have Verizon Fios Internet, cable & phone. I want to drop cable TV and phone. I have the fiber optic cable coming into the Verizon box outside and it changes over to coax that comes to the Fios Quantum router. Currently, ORBI is operating in AP mode. I want to get rid of the TV, phone and the Verizon Quantum router. I want to use only the ORBI RBR 50 and satellite router. I know ORBI does not contain a MOCA adapter inside. However, since the signal is coming in as a “internet” signal, do I need to attach a MOCA adapter to the ORBI and satellite?Would it be possible to take a pic of where your fiber is coming in? Usually Verizon FIOS uses an ONT which supports COAX and Network cable. If it supports network cable, you can connect a network cable from the ONT to the Orbi router.
- LEWB71AspirantWe’ll have to defer to next week. I’m out of town right now and won’t be able to send a picture until mid next week.
- LEWB71AspirantOk. I made it back. I think I figured it out. The fiber optic cable comes out of the ground and goes into the Verizon box mounted on the house. What comes out of there is coax only. So there is something in the Verizon box that converts the fiber optic signal into a coax one. This goes to the Verizon Quantum modem/router via coax cable to which I have the Orbi bridged in AP mode. Therefore, I believe I need two MOCA adapters; one for the main Orbi router and one for the satellite.
- MstrbigMaster
I would call Verizon and tell them you want to cancel TV and phone, and you have your own router. Inside the box is an ONT that should have multiple connections on it, one being RJ45. Tell them, if not alread there or easy to install, you want a network cable run from the ONT to your Orbi router. Then you can run the Orbi in router mode.
