shobuddy
Oct 17, 2020Aspirant
Orbi & Verizon Fios ONT not Connecting
Hello, I just purchased an Orbi RBK50 (RBR50 & RBS50) and am having trouble setting it up. I currently have Verizon FIOS (internet only) service with a G1100 modem/router. The ONT feeds an ethernet c...
- Oct 17, 2020
I was actually trying to remove the G1100 and just use the Orbi router w/one satellite. I was able to figure out how to do the release and the Orbi is now online. Thanks for your help!
Oct 17, 2020Guru - Experienced User
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
