BenjaminBollens
Jul 18, 2019Follower
Orbi +
Hello,
I'm from Belgium
Actually I use a devolo system to upgrad my wifi but that sucks ...
I'd like to buy an orbi system, but I wonder if it's a good idea to buy a netgear R7000 Nighthawk ac1900 too to connect my orbi or is it useless ?
Or do you have a better solution ? I'm open to every solution which will allow me to enhance my connexion !!
Tank you for your feedbacks !
Regards from Belgium !
1 Reply
Orbi way out performs the R7000. The R7000 is only a stand alone dual band router.
I would review these to see if Orbi would be a good fit for your needs:
https://www.netgear.com/orbi/default.aspx
https://www.netgear.com/orbi/wifi-systems.aspx
