Fowlkes523
Dec 14, 2019Aspirant
Orbi 11 Internet Connectivity Issue
Our Orbi 11 modem seems to lose connectivity to our Xfinity internet about once a day lately and I have to unplug the power and reset it. Is there a known problem with this modem or should I call Xfi...
Dec 14, 2019Guru - Experienced User
Do you have the cbk40 or which model do you have?
If you have another model, which modem is it?
If you do have a cbk40, can you take a screen snip of your modem connections page? It shows the status of your coax connectino signals.
- Fowlkes523Dec 17, 2019Aspirant
Yes, it is a CBK40. I'll try the screen shot.
- plemansDec 17, 2019Guru - Experienced User
Thanks! that'll tell us a lot about your signal strength, errors, etc.
- DominicanMacProDec 20, 2019Apprentice
So will this fix my connecting issue. I notice sometime the modem light is purple
- FURRYe38Dec 17, 2019Guru - Experienced User
Please post about this over in the CBK40 forum if you have the CBK40 cable modem with built in Orbi system:https://community.netgear.com/t5/Orbi/orbi-PERMANENTLY-ENABLE-TELNET/m-p/1837546#M78419
Fowlkes523 wrote:Yes, it is a CBK40. I'll try the screen shot.
