Fowlkes523
Dec 14, 2019Aspirant
Orbi 11 Internet Connectivity Issue
Our Orbi 11 modem seems to lose connectivity to our Xfinity internet about once a day lately and I have to unplug the power and reset it. Is there a known problem with this modem or should I call Xfi...
Dec 20, 2019Guru - Experienced User
DominicanMacPro wrote:So will this fix my connecting issue. I notice sometime the modem light is purple
Will what fix it?
I didn't see any fixes mentioned but did request some signal info.
DominicanMacPro
Dec 20, 2019Apprentice
I was asking if this would would help with my issue :https://community.netgear.com/t5/Orbi/orbi-PERMANENTLY-ENABLE-TELNET/m-p/1837546#M78419
- plemansDec 20, 2019Guru - Experienced User
Not sure how telnet is going to help you fix it.
I think the poster meant to direct you to the correct forum at
https://community.netgear.com/t5/Orbi-with-Built-in-Cable-Modem/bd-p/en-home-orbi-cable
it looks like a moderator moved your message to the correct forum.
