Kathy_J
Jan 15, 2018Aspirant
Orbi (2.1.1.16) constantly dropping wifi connection to iPad Air 2
Please help before my Orbi's life comes to a violent end! My Orbi constantly disconnects the wifi signal to my iPad Air 2. It's not just that the signal is slow. It goes completely offline. I'm on my...
Kathy_J
Adding some detail I probably should have added to the original post. Hey, it was late when I posted. ;-) Plus I have some updates.
The iPad is behaving the same way despite switching over to the 5G band
The 2.4G channel is set to "auto" (currently on channel 9)
The 5G channel is set to 48
WPA2-PSK security
WMM ON for both bands
Daisy-chain topology OFF
Implicit beamforming OFF
MU-MIMO ON
Fast roaming OFF
I've experimented with turning things on and off in different combinations and am still getting wifi disconnects.
Thanks again!!
- tucsonticoJan 16, 2018Virtuoso
Can you supply a bit more detail about your environment? For example, is your husband's iPad the same model and using the same iOS version? Is it in the same room when you're experiencing the dropouts? Do any other devices on your WiFi network display similar dropouts? What about wired devices? Are you on the router or a satellite when the drops occur? Are there any neighboring WiFi systems (potential conflicts) nearby?
Since you stated the problem appears to be with one device, I'd be suspicious of that device. Try deleteing your WiFi network from that device then power cycling (off, then on) that device and reconfiguring it to your network. I'm not a WiFi expert by any stretch of the imagination. I'm merely trying to help out with some potential fixes.
- Kathy_JJan 17, 2018Aspirant
Thanks tucsontico. Here's my best attempt at providing more details...
Same model. Same iOS. Generally the same location. He does have some dropouts but doesn't seem to be as many as me. Then again, I'm generally streaming video on mine so interruptions could be more obvious. I also use mine for much longer than he does. Funny (or not) as I'm typing this I'm having a particularly long outage. Just dead. Zero wifi. He's asleep so not using his.
Sometimes my iPhone X (and prior to that my iPhone 7) seems to be a bit flaky on wifi but I never all out lose the wifi signal. I have a wired printer, and two wired hubs connected to the router and I haven't gotten any outage notices from either of them.
The router.
Tons. I live in Silicon Valley. I've attached a screenshot of what my wifi drop down looks like. And those are just the SSIDs that are being broadcast.
OK. Done. It doesn't seem to have improved anything. :-( I've done both before, but not sure if it was in this order. Interestingly, as soon as I rebooted the iPad, I experienced a complete wifi drop on my MacBook Pro (sitting right next to it). This happens very rarely. I had to reenter my pw to get it going again.
Thanks for the help! It's appreciated. :-)
- RowverJan 17, 2018InitiateI was having similar problems with selected wifi devices on my orbi. I am running 3 satellites and one router for the orbi. (I always like having full wifi in all parts of the house) I kept having dropouts and at times certain devices just could not connect. I too tried fiddling with the same on-off settings for daisy chain, fast roaming, etc. I am currently trying "less is more". What I mean is I have since turned off 1 of the orbi satellites. It seems to give me less wifi coverage in one of the rooms but I noticed that my devices are less prone to drop the wifi or even fail to connect. It's worth a try to see if you try the same experiment and see if you get a similar result.
