Kathy_J
Jan 15, 2018Aspirant
Orbi (2.1.1.16) constantly dropping wifi connection to iPad Air 2
Please help before my Orbi's life comes to a violent end! My Orbi constantly disconnects the wifi signal to my iPad Air 2. It's not just that the signal is slow. It goes completely offline. I'm on my...
tucsontico
Jan 16, 2018Virtuoso
Can you supply a bit more detail about your environment? For example, is your husband's iPad the same model and using the same iOS version? Is it in the same room when you're experiencing the dropouts? Do any other devices on your WiFi network display similar dropouts? What about wired devices? Are you on the router or a satellite when the drops occur? Are there any neighboring WiFi systems (potential conflicts) nearby?
Since you stated the problem appears to be with one device, I'd be suspicious of that device. Try deleteing your WiFi network from that device then power cycling (off, then on) that device and reconfiguring it to your network. I'm not a WiFi expert by any stretch of the imagination. I'm merely trying to help out with some potential fixes.
Kathy_J
Jan 17, 2018Aspirant
Thanks tucsontico. Here's my best attempt at providing more details...
tucsontico wrote:Can you supply a bit more detail about your environment? For example, is your husband's iPad the same model and using the same iOS version? Is it in the same room when you're experiencing the dropouts?
Same model. Same iOS. Generally the same location. He does have some dropouts but doesn't seem to be as many as me. Then again, I'm generally streaming video on mine so interruptions could be more obvious. I also use mine for much longer than he does. Funny (or not) as I'm typing this I'm having a particularly long outage. Just dead. Zero wifi. He's asleep so not using his.
Sometimes my iPhone X (and prior to that my iPhone 7) seems to be a bit flaky on wifi but I never all out lose the wifi signal. I have a wired printer, and two wired hubs connected to the router and I haven't gotten any outage notices from either of them.
The router.
Tons. I live in Silicon Valley. I've attached a screenshot of what my wifi drop down looks like. And those are just the SSIDs that are being broadcast.
OK. Done. It doesn't seem to have improved anything. :-( I've done both before, but not sure if it was in this order. Interestingly, as soon as I rebooted the iPad, I experienced a complete wifi drop on my MacBook Pro (sitting right next to it). This happens very rarely. I had to reenter my pw to get it going again.
Thanks for the help! It's appreciated. :-)
- RowverJan 17, 2018InitiateI was having similar problems with selected wifi devices on my orbi. I am running 3 satellites and one router for the orbi. (I always like having full wifi in all parts of the house) I kept having dropouts and at times certain devices just could not connect. I too tried fiddling with the same on-off settings for daisy chain, fast roaming, etc. I am currently trying "less is more". What I mean is I have since turned off 1 of the orbi satellites. It seems to give me less wifi coverage in one of the rooms but I noticed that my devices are less prone to drop the wifi or even fail to connect. It's worth a try to see if you try the same experiment and see if you get a similar result.
- tucsonticoJan 17, 2018Virtuoso
Sorry none my original suggestions helped. Since you mentioned you live in Silicon Valley, I have to ask if you live in a detached house or an apartment complex? Regardless, if your neighbors are broadcasting on the same WiFi channels as your ORBI, you're gonna have issues! Here's and article explaining why a stronger WiFi signal is not necessarily better:
If you have a method of searching for WiFi signals and their channels/strength you can deconflict your ORBI channels pretty quickly. If not, I'd start by turning off the auto channel selection and fixing your ORBI channels. I've got mine set on Ch 1 for 2.4 gHz and Ch 48 for 5 gHz. However, I live in a semi-rural area where my nearest neighbor is 100 yards+ away. Even at that range, their WiFi signals can be seen by my EnGenius ENS202 outdoor WiFi bridge! Now those signals are at low strength (about -90dBm) but that is enough to cause collisions (ref the article linked above). You may have to adjust channels by trial & error if you cannot search by frequency, channels & strength.
Additionally, when using your WiFi devices it is best not to have them next to each other when accessing internet unless absolutlely necessary. Again, normally it shouldn't be a problem but if one device is dropping and the other isn't, it (the connected one) may be stealing the bandwidth from the other.
Finally, what firmware build are you using. I've had very good luck with 2.0.0.74. My environment is not very demanding, i.e., most of my devices are static ( IP cams, TVs, A/V equipment) and 75% are on the 2.4 gHz band. But I do have over 20 devices running simultaneously 24/7. I rarely "see" a dropout but, to date, streaming Netflix/Amazon Prime has been buffer free!
Hope you can get your ORBI tuned up for your home! Good Luck!
Thought of couple more things. Do you have the Guest Network enabled? If so, try turning that off unless you abosoluty need it. Also, try reserving IP addresses for each of your devices. You can do that through the "Advanced" tab and select the "Setup" folder then select "LAN Setup". I suggest entering a "starting and ending" IP address of your choice. (I use the total number of devices plus 4 for when friends drop in!) Then simply go through the list presented and "reserve" consecutive numbered IP address for all of the devices.
