FredFlintston
Oct 12, 2019Aspirant
ORBI 2..4 gHz speeds
Hello An ORBI RBR50 with very slow 2.4Ghz performance. I have a 50Mbs fibre service and wired connections and 5 ghz connections reach full speed but I have a tablet which is 2.4 only and it strug...
CrimpOn
Oct 12, 2019Guru - Experienced User
The satellite connection shows as "wired" and "good"?
Does this old tablet get faster speed when connected to a different WiFi system (elsewhere)?
Are there any other devices like phones, tablets, laptops, etc. which show "full speed" on 2.4G?
Are there any REALLY OLD WiFi devices connected to the Orbi?
(802.11 2.4G WiFi is "backward compatible" so that even the earliest WiFi device will still function. However, this can have the side-effect of slowing ALL 2.4G devices to the slowest speed.)
FredFlintston
Hello
Thanks for the reply. Here are the answers to the best of my knowledge:
The satellite connection shows as "wired" and "good"? Yes
Does this old tablet get faster speed when connected to a different WiFi system (elsewhere)? Yes - tethered to iphone
Are there any other devices like phones, tablets, laptops, etc. which show "full speed" on 2.4G? Most of the other stuff on 2.4 can't be tested (ipcameras and smart switches etc) My wife has a iphone 6 and she is having similar issues with often connection and full signal but no through put at all.
Are there any REALLY OLD WiFi devices connected to the Orbi? - the oldest thing is an ipad from about 2012. Everything else is less than 5 years old
- CrimpOnOct 12, 2019Guru - Experienced User
Thanks for the answers. Hmmmm. iPhone 6 is "Dual Band", so it is not clear (yet) which band it is connecting on.
Do you use the Orbi "app" or the web interface?
Are you comfortable with telnet?
- FredFlintstonOct 12, 2019Aspirant
I use the web interface mostly
i dont have much experience with telnet but can follow instructions.
As an update turing off every device and full speed came back. I could also see many other local networks around that were not listed before. The full speed remained whilst i switched everything back on one at a time - then 20 minutes later the problem is back.
My wifes phone is still fine however (showing connection as 'wired')
Can you itemize the devices which are connecting at 2.4G?
