FredFlintston
Oct 12, 2019Aspirant
ORBI 2..4 gHz speeds
Hello An ORBI RBR50 with very slow 2.4Ghz performance. I have a 50Mbs fibre service and wired connections and 5 ghz connections reach full speed but I have a tablet which is 2.4 only and it strug...
FredFlintston
Hello
Thanks for the reply. Here are the answers to the best of my knowledge:
The satellite connection shows as "wired" and "good"? Yes
Does this old tablet get faster speed when connected to a different WiFi system (elsewhere)? Yes - tethered to iphone
Are there any other devices like phones, tablets, laptops, etc. which show "full speed" on 2.4G? Most of the other stuff on 2.4 can't be tested (ipcameras and smart switches etc) My wife has a iphone 6 and she is having similar issues with often connection and full signal but no through put at all.
Are there any REALLY OLD WiFi devices connected to the Orbi? - the oldest thing is an ipad from about 2012. Everything else is less than 5 years old
(802.11 2.4G WiFi is "backward compatible" so that even the earliest WiFi device will still function. However, this can have the side-effect of slowing ALL 2.4G devices to the slowest speed.)
CrimpOn
Oct 12, 2019Guru - Experienced User
Thanks for the answers. Hmmmm. iPhone 6 is "Dual Band", so it is not clear (yet) which band it is connecting on.
Do you use the Orbi "app" or the web interface?
Are you comfortable with telnet?
- FredFlintstonOct 12, 2019Aspirant
I use the web interface mostly
i dont have much experience with telnet but can follow instructions.
As an update turing off every device and full speed came back. I could also see many other local networks around that were not listed before. The full speed remained whilst i switched everything back on one at a time - then 20 minutes later the problem is back.
My wifes phone is still fine however (showing connection as 'wired')
- CrimpOnOct 12, 2019Guru - Experienced User
Can you itemize the devices which are connecting at 2.4G?
- CrimpOnOct 13, 2019Guru - Experienced User
The next time the issue comes back, please see if this provides any information.
- Log into the Orbi web interface.
- Select the Advance Tab and make a note of the Orbi IP address (often 192.168.1.1)
- Change "index.htm" to read "debug.htm" and connect again.
- Check the box toward the bottom "Enable Telnet"
- Open a telnet program and connect to the Orbi
- Log in using "admin" and the administrative password
- Type this command:
wlanconfig ath0 list - This will list all of the devices connected to the Orbi router at 2.4G.
It's one very long line of values for each device and will probably wrap around more than once. - What you care about is the beginning of each line.
Here is the first part of mine:
ADDR AID CHAN TXRATE RXRATE
b8:c7:5d:52:02:fa 1 3 65M 65M
30:ae:a4:6c:c8:40 3 3 72M 65M
f4:b8:5e:43:88:84 4 3 58M 5M
f4:b8:5e:06:79:4d 2 3 58M 72M - The TX rate is the speed the Orbi is transmitting (TX) to the device.
The RX rate is the speed the Orbi is receiving (RX) from the device - One of these should match the MAC address of the problem iPad.
(Which can be looked up on the iPad or on the Orbi "Attached Devices" page. - What, it isn't there?
This means you have to go through the process on the satellite.
Connect to the debug page, enable telnet, log on with telnet, type the command.
This seems an enormous task at first, and I realize that only a "desperate person" would attempt it.
My hope is that it shows something interesting.
