FredFlintston
Oct 12, 2019Aspirant
ORBI 2..4 gHz speeds
Hello An ORBI RBR50 with very slow 2.4Ghz performance. I have a 50Mbs fibre service and wired connections and 5 ghz connections reach full speed but I have a tablet which is 2.4 only and it strug...
FredFlintston
Oct 15, 2019Aspirant
OK - attached for the Router first
FredFlintston
And now the satelite. This was done while down loading a netflix file on the table. At the moment things have improved to 5 - 15 Mbs
Many thanks
- CrimpOnOct 15, 2019Guru - Experienced User
Thanks for doing the test. We may not have solved your problem, but along the way this has exposed how little I knew about the "inner workiings" of WiFi on the Orbi. Things like:
- The transmit and receive rates are usually not the same. (Maybe because the antennas and radios are different, with the Orbi having larger and more powerful antennas/radios?)
- The transmit and receive rates can change dramatically over time.
- The router and satellite can be on different channels (11 and 6).
The Orbi setting is either for "Auto" or the user selects a channel.
I thought the router and satellite were always on the same channel and that "Auto" just meant that the Orbi would select one channel for both.
So, I am running out of ideas.
- FredFlintstonOct 15, 2019Aspirant
Thanks so much - i think my next move is to try my previous dual band wifi ISP thing and see if i get the same issue. This will help with the keep or return problem. I look forward to reconnecting all those devices - twice!
I have also learnt a lot going through the process - using telnet - that's almost as good as coding right?!!
I will update on the saga as I go, and someone else might see this and have another line of enquiry in the mean time
