migsta
Oct 27, 2019Apprentice
Orbi 2.5.0.38 - Absolutely Dreadful on the Devices side
Once again, Netgear releases another firmware update for absolutely no reason. They add more device selection on the iOS app but the devices updating is horrendous. It never sticks and you get diff...
Oct 27, 2019Guru - Experienced User
As mentioned, yes, the naming of devices by users is confirmed and a known issue. NG IS aware of it.
Please be patient while they fix it.
Please post about any and all Orbi app issues and experiences your seeing in the Orbi app forum and let them know about it.
https://community.netgear.com/t5/Orbi-App/bd-p/en-home-orbi-app
Good Luck.
migsta wrote:Once again, Netgear releases another firmware update for absolutely no reason. They add more device selection on the iOS app but the devices updating is horrendous. It never sticks and you get different presentations of your device names and device type everytime you come in and out of the application. I've wasted so much time trying to rename all of my device names and types but it's time to give up. It's really embarrassing that Netgear continues to flounder on this very basic fundamental. It happens with Orbi and all of their RAX series routers.
Netgear, please take a queue from Google, Eero and Synology as their device names and selections are simple, intuitive and they work. And, the Nighthawk iOS app is really bad with response times when using it. There is a lot of just waiting sometimes for the next screen to draw up.
- migstaOct 29, 2019Apprentice
And so why release a firmware update and not address this issue. Particularly, when the firmware update introduces new device types that can be selected when working with the devices. Just makes no sense on Netgears part. And, this issue has been oustanding forever it seems. It's really ALL over the place with respect to what the device listing will read. I had most of them renamed and the issue seemed to be primarily with them going back to Device Type Unknown instead of the the actual Device Type selected. Now, it's completely broken with Device Names going back to their original value and the Device Type other than what was selected/saved as well. Poor planning, poor execution, poor testing and poor deployment resulting in very poor customer experience.
- Retired_MemberOct 29, 2019
migsta wrote:And so why release a firmware update and not address this issue.
You're not a part of the 'I gott have the next FW Update Club'....you you?
- FURRYe38Oct 29, 2019Guru - Experienced User
NG will release when they get it fixed. I presume they are working on it. The are aware of it.
Please be patient.
migsta wrote:And so why release a firmware update and not address this issue. Particularly, when the firmware update introduces new device types that can be selected when working with the devices. Just makes no sense on Netgears part. And, this issue has been oustanding forever it seems. It's really ALL over the place with respect to what the device listing will read. I had most of them renamed and the issue seemed to be primarily with them going back to Device Type Unknown instead of the the actual Device Type selected. Now, it's completely broken with Device Names going back to their original value and the Device Type other than what was selected/saved as well. Poor planning, poor execution, poor testing and poor deployment resulting in very poor customer experience.
FURRYe38 wrote:NG will release when they get it fixed. I presume they are working on it. The are aware of it.
and.....DON'T do manual updates.....get it?
