armoredsaint
Oct 17, 2017Apprentice
Orbi 2 Satellites not showing up on iOS apps
I have the 3 pack from Costco, been fine for the first month, but now the 2 satellites don’t show up on the app on the iPhone and iPad. But if I log in from my desktop using a browser it works and I ...
tagteam
Oct 23, 2017Virtuoso
armoredsaint wrote:the same as yours except my Satellites will say: 0
That certainly is weird. In the Orbi app, do you see your satellites listed in the "About" section (hit the four-bar menu in the upper left corner on the home page and then "About")?
ChipParson
Mar 16, 2018Aspirant
The model number of the Rounter is RBR40 per the APP. It's not in the pull down list.
I'm having the exact same problem. They showed up originally but dropped off with Internet Online, Sataellites 0. Only see the router in the about pull down.
- DarrenMMar 19, 2018Sr. NETGEAR Moderator
Hello ChipParson
Have you used the web GUI to see if they show up there to test if its just a display bug in the IOS version?
DarrenM
- ChipParsonMar 19, 2018Aspirant
It appears to be limited to IOS. They don’t show up on my iPhone or iPad but if I log into thee GUI they show up there. It’s strange that they showed up when I first set up the network. Then they disappeared. I know they are working and both are linked into the router using 5G.
Here is a screen shot.
- DarrenMMar 20, 2018Sr. NETGEAR Moderator
Thanks for sharing the screen shot.
DarrenM
- ChipParsonMar 28, 2018Aspirant
DarrenM - Is there anything that I should try? I upgraded to the latest IOS release when it came out the other day and still the same issue.
- DarrenMApr 02, 2018Sr. NETGEAR Moderator
Hello ChipParson
We are releasing a new firmware this week what FW version are you using?
DarrenM
- Porterhouse0Sep 08, 2018AspirantMine just says...
"satellites: N/A"
The blue light is on so I know the router is seeing the satellite. But it's not showing on the app that I have a satellite connected. If the network map is supposed to show a satellite...that is also not showing a satellite - FURRYe38Sep 10, 2018Guru - Experienced User
Try removing the app from the phone, reboot the phone then re-install the app and set up from scratch...
Porterhouse0 wrote:
Mine just says...
"satellites: N/A"
