luisalvaradox
Oct 18, 2017Aspirant
Orbi 2.x Unable to Connect (iPhone 7s, Galaxy S7, S7 Edge & S8+, Samsung KS8500 TV)
The following is what I have been able to verify from about 2 weeks of experience and everything happens several times (2-6 times) a day. When using the firmware 1.x the issue was happening proba...
dsc_dewain
Oct 19, 2017Guide
I've noticed disconnects on Android phone now with V2.0.0.74 release
luisalvaradox
Oct 19, 2017Aspirant
Yes, still disconnecting for Android and also other devices as mentioned in the original post. I also found that smallnetbuilder had created a https://www.smallnetbuilder.com/tools/rankers/wifi-system/result/3659-netgear-rbk50?testmethod=36 to test Orbi, but based on this, it was using the 1.x versions and they showed working correctly, but on the 2.x they simply dropped 2x to 4x times from the recorded speeds there.
