jzryk8
Nov 09, 2019Tutor
orbi 20 cannot connect Swann Camera
Newbie here. Installed my Obrbi RBR20 yesterday and all working ok apart from the fact I cannot seem to connect my Swann Indoor WiFi Camera (SWWHD-INTCAM). It does not seem to be able to see the ...
- Nov 10, 2019
I really wish to thank you all for the explicit instructions. Especially about simply turning off the SSID visibility on the band.
All fixed now, so many many thanks to all.
Regards
Nov 09, 2019Guru - Experienced User
Are you using a custom SSID or default ORBI## SSID?
Is the camera 2.4Ghz only supporting or does it support 5ghz by chance?
