jzryk8
Nov 09, 2019Tutor
orbi 20 cannot connect Swann Camera
Newbie here. Installed my Obrbi RBR20 yesterday and all working ok apart from the fact I cannot seem to connect my Swann Indoor WiFi Camera (SWWHD-INTCAM). It does not seem to be able to see the ...
- Nov 10, 2019
I really wish to thank you all for the explicit instructions. Especially about simply turning off the SSID visibility on the band.
All fixed now, so many many thanks to all.
Regards
jzryk8
Nov 09, 2019Tutor
Hi thanks for the reply.
Firmware is V2.3.1.58AU
Using a custom SSID
Unfortunately I think that is the problem on the Band, is a 2.4 Camera and my iPhone (which has the Camera Setup App) is defaulting to the 5.
Regards
Nov 09, 2019Guru - Experienced User
Ah ok, so it's the Cameras setup software on the mobile device is the problem. Yes, we've seen this before.
This should help:
Just need to temporarilty disable the 5G SSID broadcast. Disable the wifi on your phone and wait for the change on the RBR to happen. After it completes, re-enable the wifi radio on your mobile device and it will connect to the 2.4Ghz SSID on the RBR. Run the camera setup software.
Let us know how it goes...
