jzryk8
Nov 09, 2019Tutor
orbi 20 cannot connect Swann Camera
Newbie here. Installed my Obrbi RBR20 yesterday and all working ok apart from the fact I cannot seem to connect my Swann Indoor WiFi Camera (SWWHD-INTCAM). It does not seem to be able to see the ...
- Nov 10, 2019
I really wish to thank you all for the explicit instructions. Especially about simply turning off the SSID visibility on the band.
All fixed now, so many many thanks to all.
Regards
jzryk8
Nov 09, 2019Tutor
Hi, quick question, How do I turn off 5 GHz SSID broadcast.
michaelkenward
Nov 10, 2019Guru - Experienced User
Good question. We need step by step details for that for future reference.
- Login to Orbi graphical user interface (GUI)
- Advanced
- Advanced Setup
- Wireless Settings
- Look for Advanced Wireless Settings (5GHz 802.11a/n/ac)
- Uncheck Enable SSID Broadcast
Do your thing and go back and reverse the process.
- FURRYe38Nov 10, 2019Guru - Experienced User
Be sure to disble the wifi radio on your mobile device before you start to turn OFF the 5G SSID broadcast on the RBR. Then turn it back ON after the 5G has been disabled. This ensures the mobile device has disconnected fully from the 5G and re-connects to the 2.4G broadcast.
michaelkenward wrote:
jzryk8 wrote:Hi, quick question, How do I turn off 5 GHz SSID broadcast.
- Advanced
- Advanced Setup
- Wireless Settings
