Samsioe
Sep 24, 2019Aspirant
ORBI 20 slow speed on 2,4G
Hi all! Just replaced my AIMesh system with ORBI AC2200 due to AIMesh instability. Decided to keep one ASUS Router as router and has setup the ORBI RBR20 as an AP. Everything runs well and smooth...
- Sep 25, 2019
Ya if you only have 2 RBS, you can disble Daisy Chain.
Glad it's working well now. Please mark your thread as solved so others will know.
Enjoy. :smileywink:
Sep 24, 2019Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Reboot both Orbi system and wireless device your testing with.
Try a different wireless device to test with to compare...
Samsioe
Hi and thank for respons!
Using latest firmware.
Apprx 90 sq meters.
Distance approx 10 meters
Currently ch 11.
WiFi Neighbors 3 visible in WiFi analyzer at <-80dBm.
I have finally solved the problem and has now approx 100 Mbit/s on 2,4 Ghz. Did a factory reset on both router and sattelite and a new installation from start using the WEB Gui. My setup is as follows:
AP mode
Circle disabled
Guest disabled
Coexistense 20/40 disabled
WMM enabled
Daisy chain enabled (could be disabled I guess as I only have one sattelite)
Implicit beamforming enabled
MU-MIMO enabled
Fast Roaming enabled
With above setup 2,4G now runs smoothly with 40 MHz bandwith and approx 100Mbit/s throuput.
So problem solved!
- FURRYe38Sep 25, 2019Guru - Experienced User
Enjoy. :smileywink:
