Samsioe
Sep 24, 2019Aspirant
ORBI 20 slow speed on 2,4G
Hi all! Just replaced my AIMesh system with ORBI AC2200 due to AIMesh instability. Decided to keep one ASUS Router as router and has setup the ORBI RBR20 as an AP. Everything runs well and smooth...
- Sep 25, 2019
Ya if you only have 2 RBS, you can disble Daisy Chain.
Glad it's working well now. Please mark your thread as solved so others will know.
Enjoy. :smileywink:
Samsioe
Hi and thank for respons!
Using latest firmware.
Apprx 90 sq meters.
Distance approx 10 meters
Currently ch 11.
WiFi Neighbors 3 visible in WiFi analyzer at <-80dBm.
I have finally solved the problem and has now approx 100 Mbit/s on 2,4 Ghz. Did a factory reset on both router and sattelite and a new installation from start using the WEB Gui. My setup is as follows:
AP mode
Circle disabled
Guest disabled
Coexistense 20/40 disabled
WMM enabled
Daisy chain enabled (could be disabled I guess as I only have one sattelite)
Implicit beamforming enabled
MU-MIMO enabled
Fast Roaming enabled
With above setup 2,4G now runs smoothly with 40 MHz bandwith and approx 100Mbit/s throuput.
So problem solved!
Sep 25, 2019Guru - Experienced User
Enjoy. :smileywink:
