Bruiser2's avatar
Bruiser2
Follower
May 14, 2020
Orbi 20 Wifi not working when PC wired to router is off or asleep
It seems that the wifi stops on the Orbi 20  working when the PC hard wired to the router is off or asleep. If you turn the PC on or wake it, the wifi starts working again
Any thoughts anyone
1 Reply
  • FURRYe38's avatar
    Disable any power management features on the wifi and lan adapter on this pc.
    Disable the wifi adapter under networking settings while using the wired connection. Re-enable it when the wifi adapter is needed.
