ChunkyPlumpy
Nov 18, 2020Aspirant
Orbi 20 Wired Satellite - Thinks it's 5G
Hello, I'm hoping someone can help. I'm using the BT router with WIFI disabled, the Orbi mesh replaces the WFI and simply passes DHCP etc to the BT router (AP Mode). When logged into the RBR ...
Nov 18, 2020Guru - Experienced User
RBS should be wirelessly connected first then connect the ethernet cable between the RBR to RBS...
Is there a LAN switch use in between the RBR and RBS?
RBS are connected back haul over 5G when wirelessly connected.
ChunkyPlumpy
Nov 19, 2020Aspirant
Thank you Furry for your quick reply, and appologies for my newbie error since I did actually search for help before posting and missed that page! Luckily I have done exactly as the document suggested, fought hard to reset everything and finally configured the system using WIFI. I then relocated the wired device and connected via ethernet as the final step.
As for the network configuration, there is indeed a gigbit LAN switch between the devices... possibly two but I can't remember without tracking back. The wired connection was a problem, it was throttled at 100Mbs but I changed to a CAT6 cable from the device and all was fine again.
The only issue is that the RBR does not detect the ethernet backhall and consequently the RBR driven firmware upgrades and maybe other general management from the RBR, does not work. It's a shame but I can live with it, I'm just a bit surprised by the 'fiddliness' of the whole solution and these shortfalls (lets not forget the 'app' doesn't even run). At c£450 for the full rig it's a lot of money for something that 'does the job'.
I digress, thank you for confirming the setup, it was helpful and as stated the system is running again. Cheers!
