ChunkyPlumpy
Nov 18, 2020Aspirant
Orbi 20 Wired Satellite - Thinks it's 5G
Hello, I'm hoping someone can help. I'm using the BT router with WIFI disabled, the Orbi mesh replaces the WFI and simply passes DHCP etc to the BT router (AP Mode). When logged into the RBR ...
Nov 19, 2020Guru - Experienced User
What is the Mfr and model# of the ethernet switch in the configuration?
The RBR will always report wired connections with RBS if they are connected correctly and with out any connection problems.
ChunkyPlumpy
Nov 20, 2020Aspirant
Hello,
The satellite hangs off a LINKSYS LGS105, which might run into a NETGEAR GS105 or goes straight into the BT Smart Hub 2; they both terminate on the hub as opposed to the RBS terminating in the back of the RBR. The second switch is tucked away so in truth I can't recall if it goes through the NETGEAR or stright to the BT Smart Hub 2 from the LINKSYS?
With you having confirmed that the configuration should be valid and recognised then I need to do some further investigation. The network has grown over the years so it could be there is an old or lower spec CAT5 cable between switches, perhaps a switch is two old or maybe you must terminate into the back of the RBR before the BT router?
Any pointers would be appreciated, this is the very last issue but tracing could be tricky given the hops and jumps between devices. Cheers!
- FURRYe38Nov 20, 2020Guru - Experienced User
Ok, one thing, the RBS cable line needs to terminate at and behind the RBR. Not the Hub. Try this first.
If this doesn't change the behavior, then look at either of the switches in this line and swap out or remove one if possible to test the line with the RBS.- ChunkyPlumpyNov 22, 2020Aspirant
Hi Furry, sorry for the delay responding. I appreciate your help but was not able to pull the plug on things until this morning, as with lockdown here the internet was somewhat in demmand!
I have terminated both the RBR and wired RBS into the same switch, the Netgear one which I have to assume ticks all the right boxes. The Syslink remains in the onward connecton to the RBS at the moment but before I unplug that temporarily to test further I noticed that this new configuration shows something unseen previously in the RBR admin panal:
The wired RBS (Satellite-3) is now reporting it is a Linux device and not an actual Orbi device. Does this shed any light on things, as it still thinks it is a 5G connection but I wonder if this Linux logo has been seen before and perhaps narrows down my search?
Cheers.
- FURRYe38Nov 22, 2020Guru - Experienced User
Which mfr and model switch are you using between the RBR and RBS?
What FW version are you using?
I presume you directly connect the RBS to the back of the RBR, the status is wired and the icon is correct?
