ChunkyPlumpy
Nov 19, 2020Aspirant
Orbi 20 Wired Satellite - Thinks it's 5G
Hello, I'm hoping someone can help. I'm using the BT router with WIFI disabled, the Orbi mesh replaces the WFI and simply passes DHCP etc to the BT router (AP Mode). When logged into the RBR ...
Nov 23, 2020Guru - Experienced User
Which mfr and model switch are you using between the RBR and RBS?
What FW version are you using?
I presume you directly connect the RBS to the back of the RBR, the status is wired and the icon is correct?
ChunkyPlumpy
Nov 28, 2020Aspirant
Hi, sorry this went a bit dead but work stopped play and I couldn't take the network off line. I'm going to try and connect the satalitte directly into the back of the router to eliminate everything else as I've not made any progress swapping things out and changing switches. Will come back when I've done that as it 'should' be peachy with a direct connection.
Cheers.
