hariou
Dec 09, 2019Aspirant
Orbi 3000: Max Satellites
Hi. In the Pro version, there router supports unofficially 6-7 satellites. Is this the same for the home version? Anyone try more than three?
CrimpOn
Dec 09, 2019Guru - Experienced User
Yes, forum members have reported as many as 6 satellites on one Orbi residential system.
hariou
Thanks. As follow up question, in the documentation there is an example of using a hub/router for wired backhaul. Is this the highest performance setup? I imagine it only becomes relevant if alot of traffic and clients. What percentage wise does it help?
Thnx
Thnx
- FURRYe38Dec 10, 2019Guru - Experienced User
Wired LAN connections will always have better performances over wireless.
Wireless backhaul speeds on 50 series systems is 1733Mpbs This is only between the RBR and RBS.
Wireed backhaul and LAN cable connections is 1000Mbps. In this configuration, 1000Mbps is the max rate between the RBR and RBS and any LAN connected device plug into the LAN ports on the RBR or RBS. Lan ports are max rated at 1000Mbps.
Thnx- hariouDec 10, 2019AspirantThanks. To clarify question for wired connections is using a hub better than a chain link topology?
- CrimpOnDec 10, 2019Guru - Experienced User
hariou wrote:
What percentage wise does it help?I have never seen a post comparing maximum performance when many satellites are connected with ethernet rather than using the standard 5G WiFi backhaul. There simple are too many variables. The concensus on the forum is that "wired is better", if you can do it.
