jengard
Jun 03, 2019Follower
Orbi 40
How do I log in and check to see if 5 different ports are open??? I need to ake sure because we can't get our PS4 to connect to internet and PS4 said it is the routers ports are not open
1 Reply
What FW is currently loaded?
What is the Mfr and model# of the ISP modem the NG router is connected too?If uPnP is enabled, this is all you need, however need to check your ISP modem for router or NAT here first.
