Mullane
Aug 14, 2020Aspirant
Orbi 4GX Router with Satellite
Good morning we just bought the 4G Lite from Telstra. I am unable to get any help from them. I tried to install it but it is saying we need a APN number. Any ideas?
CrimpOn
Aug 14, 2020Guru - Experienced User
Mullane wrote:Good morning we just bought the 4G Lite from Telstra. I am unable to get any help from them. I tried to install it but it is saying we need a APN number. Any ideas?
The APN number comes from the telecom company that provided the SIM card that has been put into the LTE router.
See page 20 and page 23 of the user manual:
https://www.netgear.com/support/product/lbr20.aspx
- MullaneAug 14, 2020AspirantThanks. I got the information from my internet provider but it won’t accept it in the app when I am trying to set it up. It just keeps saying something went wrong. Input in the APN value do I then use my username and password for internet provider or Netgear name and password I set up? Sorry I’m not great with this sort of thing.
- ArodiDAug 16, 2020NETGEAR Expert
Hi There,
It has been identified that the power adapter for the satellite has been incorrectly labelled as "router". Please make sure you are using the larger 2.5A power adapter with the router and the smaller 1A power adapter(incorrectly labelled router) with the satellite. Please let me know if you still experience issues after using the correct PA.
Arodi
- Skybolt36Feb 02, 2021AspirantHi, just wondering if you got your APN fixed, I’m having exact same problem and also unsure if the UN and PW is for Telstra account of the modem? Such badly set out instructions
- Lisa_TMar 10, 2021AspirantI’m having the same issues with mine. Have tried the telstra.internet but that don’t work either. Telstra were no help. They asked - what do you mean Orbi!
