macleodcal27
Feb 19, 2021Follower
Orbi 4GX Router
I am trying to connect my Orbi 4GX router to NBN broadband however it does not seem to be able to connect. It works fine SIM only, but i now want to use the router and satelleite for NBN Broadban...
Feb 20, 2021Guru - Experienced User
From looking at the manual (I don't have that router), it seems like you need to disable the mobile broadband to setup wired internet connection.
Page 22 of the manual goes over it.
https://www.downloads.netgear.com/files/GDC/LBR20/Orbi_LBR20_UM_EN.pdf
