VAEAGLE367
Sep 26, 2020Aspirant
Orbi 5 to Orbi 6 Upgrade Question
I will be upgrading my home network from Orbi 5 to an Orbi 6 (AX6000) network. I have 42 wifi connections in my home. Will I be able to "clone" the Orbi 5 network settings in my Orbi 6? In other words, if I use the same network name and password, will it just connect to my devices as usual? I really don't want to have to reset everything. Also, since I already have the app on my phone, will I have to do anything with that?
Thanks!
1 Reply
Yes you can use same SSID name and PW on Orbi AX.
Be sure visit the Orbi AX forum for your Orbi AX quesions, help and information:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Good Luck.
