Jds101
Jan 21, 2021Aspirant
Orbi 50 - flashing white / magenta satellites
I purchased the Orbi50 system from costco last year. It has worked great until a couple of days ago when I noticed the RBR flashing white and all the RBS magenta. I checked the modem and it indenticat...
Jan 21, 2021Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
https://kb.netgear.com/19668/Link-Rate-and-Transfer-Speed
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
