Jds101
Jan 21, 2021Aspirant
Orbi 50 - flashing white / magenta satellites
I purchased the Orbi50 system from costco last year. It has worked great until a couple of days ago when I noticed the RBR flashing white and all the RBS magenta. I checked the modem and it indenticat...
vajim
Jan 21, 2021Master
Jds101 wrote:
I purchased the Orbi50 system from costco last year. It has worked great until a couple of days ago when I noticed the RBR flashing white and all the RBS magenta. I checked the modem and it indenticated nothing was connected. To troubleshoot I disconnected the orbi and plugged my laptop directly into the modem and my laptop worked fine. So clearly the issue is with Orbi, I tried calling netgear but they want $100 to trouble shoot?!?! What a scam... they should stand behind their product.
I tried reseting the RBR, holding in the button for 15 seconds but nothing happens, just keeps blinking white, no amber. The Orbi app is unable to connect as well.
Any idea what caused this and how to fix?
Magenta usually means the device has lost connection
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
- Jds101Jan 21, 2021AspirantI tried factory reset, held a paper clip for over a minute and the RBR still flashes white, never amber.
- vajimJan 21, 2021Master
Jds101 wrote:
I tried factory reset, held a paper clip for over a minute and the RBR still flashes white, never amber.Dead?
how old?
- Jds101Jan 21, 2021AspirantI purchased it last year...
- FURRYe38Jan 21, 2021Guru - Experienced User
Power OFF both ISP Modem and RBR for 30 seconds, then back ON with the modem first, then RBR...
Can you access the RBRs web page at 192.168.1.1 with a web browser?
