ChrisLF
Jun 17, 2019Aspirant
Orbi 50 blocking Homekit connections
Insyalled new Orbi RBK50 yesterday and downladed the latest firmware. Compared to my previous Apple Air Extreme router, download speeds to ios devices generally doubled (although, wierdly, upload sp...
- Jun 18, 2019
You don't have to change the power levels on the Orbi for 5Ghz anymore, you can temporarily disable the 5Ghz SSID while you configure 2.4Ghz only devices to see if that helps any. Under Advanced Tab/Advanced Settings/Wireless Settings
Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM.
Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
ChrisLF wrote:Insyalled new Orbi RBK50 yesterday and downladed the latest firmware. Compared to my previous Apple Air Extreme router, download speeds to ios devices generally doubled (although, wierdly, upload speeds were cut in half). However, a dozen of my previously installed Homekit devices now show up as unresponsive in my Homekit app on my IOS devices (a Hue light controller, which is connected to the Orbi hub by etherenet, and its wirelessly connected hue bulbs work fine). I tried re-intiaslizing one of the unresponsive devices, but although my iphone could recognize the device from its code, it could not connect it to the network. This is likely because the iphone is connected to the Orbi's 5Ghz band while these devices are, as usual, only able to connect on the 2.4 Ghz band. The same problem existed with Apple's system, but you could solve the problem by choosing which band the ios device connected too. I see no way to do that with Orbi's software. I presume many must be having the same problem. I chatted with support but their suggestions didnt address the band problem and they ended up blaming Apple. Any suggestions out there?
Jun 18, 2019Guru - Experienced User
ChrisLF
Jun 18, 2019Aspirant
Thanks, FURRYe38. I didn't find the Beamforming option but changed the others; this didn't work initially. Then I set the 2.4 and 5Ghz channels manually to 1 and 48 respectively. This changed my iphone connection (previously always at 5 Ghz) to 2.4Ghz. I still couldn't connect to my existing homekit devices, thoiugh, and had to reset all of them. Two Koogeek devices are still refusing to connect, but the others all did, so most of my network is back on line. I have reset the switches to original configuration and my iphone is connecting again at 5Ghz but the homekit devices are still connected. I appreciate your help. Really, though, I hope Netgear can come up with an easier solution.
