ChrisLF's avatar
ChrisLF
Orbi 50 blocking Homekit connections
Insyalled new Orbi RBK50 yesterday and downladed the latest firmware.  Compared to my previous Apple Air Extreme router, download speeds to ios devices generally doubled (although, wierdly, upload sp...
  • FURRYe38's avatar
    Jun 18, 2019
    You don't have to change the power levels on the Orbi for 5Ghz anymore, you can temporarily disable the 5Ghz SSID while you configure 2.4Ghz only devices to see if that helps any. Under Advanced Tab/Advanced Settings/Wireless Settings
    Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM.
    Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
    Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
    ChrisLF wrote:
    Insyalled new Orbi RBK50 yesterday and downladed the latest firmware.  Compared to my previous Apple Air Extreme router, download speeds to ios devices generally doubled (although, wierdly, upload speeds were cut in half).  However,  a dozen of my previously installed Homekit devices now show up as unresponsive in my Homekit app on my IOS devices (a Hue light controller, which is connected to the Orbi hub by etherenet, and its wirelessly connected hue bulbs work fine).  I tried re-intiaslizing one of the unresponsive devices, but although my iphone could recognize the device from its code, it could not connect it to the network.  This is likely because the iphone is connected to the Orbi's 5Ghz band while these devices are, as usual, only able to connect on the 2.4 Ghz band.  The same problem existed with Apple's system, but you could solve the problem by choosing which band the ios device connected too.  I see no way to do that with Orbi's software.  I presume many must be having the same problem.  I chatted with support but their suggestions didnt address the band problem and they ended up blaming Apple. Any suggestions out there?
