Stella01
Jun 17, 2019Aspirant
Orbi 50 not allowing connection to streaming services
I just installed the Orbi. My problem is that none of my streaming services accessed through a Roku, Nvidia shield or AppleTV will play content. I am able to access the interfaces all apps on these d...
- Jun 19, 2019
Success!! I am having zero issues now that I have set the Orbi to AP mode. Thanks SO much for your help and patience. I am a little surprised there was not more upfront info concerning how different modems require different setups. However, thanks for everything.
Jun 18, 2019Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
