Stella01
Jun 17, 2019Aspirant
Orbi 50 not allowing connection to streaming services
I just installed the Orbi. My problem is that none of my streaming services accessed through a Roku, Nvidia shield or AppleTV will play content. I am able to access the interfaces all apps on these d...
- Jun 19, 2019
Success!! I am having zero issues now that I have set the Orbi to AP mode. Thanks SO much for your help and patience. I am a little surprised there was not more upfront info concerning how different modems require different setups. However, thanks for everything.
Jun 18, 2019Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Stella01
Jun 18, 2019Aspirant
Wow, lots of things!
the firmware was updated to the latest, sorry don’t know the #. The modem is the stock AT&T modem/router with a fiber connection. I have since uninstalled the Orbi so some of the info is not available. However, your question about AP mode versus Router mode sounds like it might be an issue. My setup was done via netgear mobile app and everything was done in “auto-mode”. My sassumtion it was setup in router mode. This might be a problem since my AT&T modem is also a router, which from digging a little bit, would suggest it should be set up in AP mode. Maybe this is my problem. One of devices that would not connect did give me an error message of “Port 80 cannot find the expected ....” so a problem with port 80, whatever that might suggest. Of course, this is beyond my technical grasp, but I would love to get this working. I will try all your suggestions and report back. Thanks so much.
- FURRYe38Jun 18, 2019Guru - Experienced User
Ya, having a router at the modem will cause problems.
Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop- Stella01Jun 18, 2019Aspirant
Thanks. I can certainly easily do #2 & 3, since the WiFi is disabled on my AT&T modem. What is the advantage of #1? Obviously, talking with AT&T about anything is a hassle and a crapshoot.
I would need to have the Orbi router be able to also connect via wire, Also the satellite. Is this available in scenario 2 & 3? Sorry for being so unsophisticated regarding these things, but this stuff is SO beyond my understanding. Thanks for your patience
- plemansJun 19, 2019Guru - Experienced User
Stella01 wrote:Thanks. I can certainly easily do #2 & 3, since the WiFi is disabled on my AT&T modem. What is the advantage of #1? Obviously, talking with AT&T about anything is a hassle and a crapshoot.
From my reading AT&T is horrible about letting their devices be placed in modem only mode. So option 1 probably isn't much of an option.
I've never used option 2 that FURRYe38 listed.
I have used option #3 with orbi and it worked great. Only downfall is losing some of Orbi's advanced functions such as Circle/Armor/advanced lan settings/etc.
You do need the main Orbi connected back to your ATT box via a ethernet wire. The satellite can be hooked up via the wireless backhaul or a wired backhaul. Either will work for both scenarios.
