Rosstheboss57
Jul 30, 2020Aspirant
Orbi 50 router wifi not working or eithernet to desktop
Hi I’ve had my router & satellite for 2 yrs. suddenly WiFi not working. Router will not hook up and the eithernet cord to my desktop does not work. If I hook up the computer directly to the cable rout...
CrimpOn
Jul 30, 2020Guru - Experienced User
Can you describe the behavior of the Orbi power and "ring" LED's when the router is powered on?
https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-mean
- Rosstheboss57Jul 31, 2020AspirantIt blinks white then goes to purple. Wireless does not work. If I have my desktop plugged in to the orbi router via ethernet has no internet but if I plug computer in directly to the modem computer has internet. Problem with orbi router
