Rosstheboss57
Jul 30, 2020Aspirant
Orbi 50 router wifi not working or eithernet to desktop
Hi I’ve had my router & satellite for 2 yrs. suddenly WiFi not working. Router will not hook up and the eithernet cord to my desktop does not work. If I hook up the computer directly to the cable rout...
Jul 31, 2020Guru - Experienced User
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? IF this has a built in router and wifi, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
- Rosstheboss57Jul 31, 2020AspirantThanks but no changes in the provider or modem. There is no WiFi in the modem. All was working well until recently. It is strange that Ethernet cord from orbi hardwire to my computer dosent send signal either.
- FURRYe38Jul 31, 2020Guru - Experienced User
Try a factory reset on the RBR.
Swap LAN cables.
Same thing happens with a different PC?
- Rosstheboss57Jul 31, 2020AspirantThanks I’ve changed the cord. I hooked up old WiFi which works but not strong for entire house. I’ve tried a factory reset the router doesn’t even show up to install. I do see a neighbors orbi And lots of other networks
