Rosstheboss57
Jul 30, 2020Aspirant
Orbi 50 router wifi not working or eithernet to desktop
Hi I’ve had my router & satellite for 2 yrs. suddenly WiFi not working. Router will not hook up and the eithernet cord to my desktop does not work. If I hook up the computer directly to the cable rout...
Rosstheboss57
Jul 31, 2020Aspirant
Thanks but no changes in the provider or modem. There is no WiFi in the modem. All was working well until recently. It is strange that Ethernet cord from orbi hardwire to my computer dosent send signal either.
Jul 31, 2020Guru - Experienced User
Try a factory reset on the RBR.
Swap LAN cables.
Same thing happens with a different PC?
- Rosstheboss57Jul 31, 2020AspirantThanks I’ve changed the cord. I hooked up old WiFi which works but not strong for entire house. I’ve tried a factory reset the router doesn’t even show up to install. I do see a neighbors orbi And lots of other networks
- FURRYe38Jul 31, 2020Guru - Experienced User
Not even with a wired PC connected and a web browser pointed at 192.168.1.1?
- MstrbigJul 31, 2020Master
So you are saying, you factory reset your Orbi RBR50, unplugged and plugged your ISP modem back in after a minute, plugged your Orbi into the ISP modem and powered it up, went to the app and performed an install, and you cannot see the Orbi to install it or it installs but has no WIFI? If it installs and has no WIFI, can you go to a wired PC and go to http://192.168.1.1 and log in?
