Casbah
Nov 27, 2019Follower
Orbi 50
I did a hard reset on the Orbi 50 now they won’t be 50 will not take my password
CrimpOn
Nov 27, 2019Guru - Experienced User
A "factory reset", where the power LED turns amber and begins to flash, will reset the Orbi to the way it came from the factory. The WiFi SSID and password will be what is printed on the router label (usually on the bottom of the unit).
Is this not what has happened?
