Srmodi1963
Apr 06, 2020Tutor
Orbi 53 with latest firm updates and satellite does not show any devices
I updated firmware and my satellite does show any device ms connection. Internet is fine all satellites are working fine 4 of them just on orbi app all show green and connected but does now show any d...
Retired_Member
Apr 08, 2020
Srmodi1963 wrote:
I updated firmware and my satellite does show any device ms connection. Internet is fine all satellites are working fine 4 of them just on orbi app all show green and connected but does now show any device connected. Why before old firmware it used to show which device connected to which satellite. Please can somebody explain or is it firmware problem?? Or some thing else
Why did you update the firmware?
- Srmodi1963Apr 08, 2020TutorMy orbi app It says new firmware is available and I should update it. This was there for 3 months ( since dec 19) I ignored it until now. And updated last week. Now all are up to date. But this problem arise. I want to fix only is easy fix otherwise wait until next update.
- Retired_MemberApr 08, 2020
Srmodi1963 wrote:
My orbi app It says new firmware is available and I should update it. This was there for 3 months ( since dec 19) I ignored it until now. And updated last week. Now all are up to date. But this problem arise. I want to fix only is easy fix otherwise wait until next update.My advice is revert back now to the version that was stable for you.
In the future do NOT do any manual (App or Email) updates, When you NEED an update NG will push it to you with no action required by you.
- FURRYe38Apr 08, 2020Guru - Experienced User
Try a factory reset and setup from scratch with the RBR and RBS.
Srmodi1963 wrote:
My orbi app It says new firmware is available and I should update it. This was there for 3 months ( since dec 19) I ignored it until now. And updated last week. Now all are up to date. But this problem arise. I want to fix only is easy fix otherwise wait until next update.- Srmodi1963Apr 08, 2020TutorIthank you
I donot have issue with internet right now with any devices just not showing any devices connection on app even they are connected. I will not do any new update let NG do auto update.
I do not know how to go back to old firmware so I just continue as is until next Update comes and see.
