Srmodi1963
Apr 06, 2020Tutor
Orbi 53 with latest firm updates and satellite does not show any devices
I updated firmware and my satellite does show any device ms connection. Internet is fine all satellites are working fine 4 of them just on orbi app all show green and connected but does now show any d...
Srmodi1963
Apr 08, 2020Tutor
My orbi app It says new firmware is available and I should update it. This was there for 3 months ( since dec 19) I ignored it until now. And updated last week. Now all are up to date. But this problem arise. I want to fix only is easy fix otherwise wait until next update.
Retired_Member
Apr 08, 2020
My advice is revert back now to the version that was stable for you.
In the future do NOT do any manual (App or Email) updates, When you NEED an update NG will push it to you with no action required by you.
