Cvang1989
Jan 02, 2022Aspirant
Orbi 5G Router NBR750 & Ring Stick Up Cam
Hello I'm hoping that someone can help me. I have recently purchased a Orbi 5G Router NBR750 but I cannot get it to work with my Ring Stick Up Camera. I can get all of my other ring devices to work (e...
Cvang1989
Jan 19, 2022Aspirant
Are you having the same issue?
The best thing for me was to just return the product. As much as I liked it, there isn't anything you can use (not to my knowledge) to use it as a home internet. Not sure where you can find a plan or carrier that would give you montly unlimited data (if not, at least more then 50GB) for a reasonable price. I thought that I was going to be able to go through T-Mobile with their 100GB but I thought wrong. Orbi will only work with the 50GB per month and my kids need it way more than that. The struggles I had with this device connecting to my Ring camera's and no more than 50GB made me submit it back in as a return. If you only needed 50GB per month it might work for you.
Jan 19, 2022Guru - Experienced User
I don't have this specific model product.
If it's not working for you then it maybe best to return it and find something that does.
Good Luck.
