ckeyes888
Dec 08, 2021Follower
Orbi 6 Wifi Dropouts
Hoping there's been some progress and/or fixes to the severe dropout issues
with these units?
About ready to trash mine.
Thanks,
Carl
1 Reply
Would probably get a more informed response if you can summarize the problem. (There are so many posts every day that what is obvious to you may not "ring a bell" with others.)
Also, the forum where customers discuss WiFi 6 Orbi products is here:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
You could skim the posts in that forum to see if one matches your issue, or search that forum.
Good Luck.
p.s. If you really mean "trash", I'd be happy to pay the shipping to have one to experiment with.
