sjm1967
Jul 09, 2021Aspirant
orbi 6
hello, i purchased 2 x orbi packs and 2 seperate orbis so i could have a total of 6 units withb only using 1 router the 2 units woth the pack connect ok and the 2 extra units connect ok but it tran...
Jul 09, 2021Guru - Experienced User
What model Orbi are you referring to? RBK50 series or RBK 7 or 8 series?
- sjm1967Jul 09, 2021AspirantRbk853 I believe
- FURRYe38Jul 09, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the Orbi AX (WiFi 6) products. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-axThank you.
