sjm1967
Jul 09, 2021Aspirant
orbi 6
hello, i purchased 2 x orbi packs and 2 seperate orbis so i could have a total of 6 units withb only using 1 router the 2 units woth the pack connect ok and the 2 extra units connect ok but it tran...
CrimpOn
Jul 09, 2021Guru - Experienced User
sjm1967 wrote:how do we default / reset the two units so they will connect to a different router
i have tried all the usual factory defaults and nothing seems to work
It sounds like the Factory Reset was not done completely.
https://www.youtube.com/watch?v=cMw4ePACgc4
Either the WPS method or the web mamagement "Add an Orbi Satellite" method should work
sjm1967
thankyou, i will try this
