Dhuffstu
Nov 29, 2018Tutor
Orbi AC 2200 12V/1.5A power adapters replacement (need: 220V 50hz)
I have the AC2200 RBK23. Just realized it does NOT have dual voltage power adapters (wall plugs). Can anyone recommend a 220V 50hz replacement? Thank you!
Dhuffstu
Dec 01, 2018Tutor
I think I found a workable option if anyone is looking: https://www.amazon.com/gp/product/B07HNL5D56/ref=ox_sc_act_title_1?smid=A14FP9XIRL6C1F&psc=1
michaelkenward
Dec 01, 2018Guru - Experienced User
Looks good.
Is that the Netgear tip size?
If so, thanks for the information. I have been trying to track down those dimensions. Netgear's manuals seem to be silent on that bit of the specifications.
I usually go for something with exchangeable tips.
Remember, if you leave the USA you will need an adaptor.
- DhuffstuDec 01, 2018Tutor
We measured everything (inluding the tips - 2.1mm * 5.5mm Center Positive Barrel Plug) and checked the electrical stats. As far as I can tell with everything online, it should be identical.
We use multiplug extension cords/adapters and voltage regulators for so many things overseas, so we should be set with an adapter. But yes...otherwise, an adapter would be required.
- Caveman_323Jan 08, 2019GuideDid that power adapter work? I am same situation. All my previous Netgear products were dual voltage. I ordered a new EX7700 extender and its says 120v 50/60hz 12v 1.5A. Most all transformers are dual voltage these days WTF Netgear?
- michaelkenwardJan 08, 2019Guru - Experienced User
Caveman_323 wrote:
I ordered a new EX7700 extender and its says 120v 50/60hz 12v 1.5A. Most all transformers are dual voltage these days WTF Netgear?Has it arrived yet? Where did you order from?
Netgear has started to supply 100-240 volt adapters, but there are still too many old ones out there.
Some people have found that the labels on adapters are not accurate. They say 100-120V but they actually handle 100-240V. Might be down to legal requirements in the USA.
