HMF22112's avatar
HMF22112
ORBI AC2200 = satellite keeps defaulting to 2.4
ORBI AC2200 = one satellite gets 5.0, but the other keeps defaulting to 2.4.
Any way to fix this, or do I need to return it?
My son says there is a Nighthawk that works better.  Please advise.
  • FURRYe38's avatar
    What do you mean by defaulting to 2.4?
    What devices are you connecting to the Orbi system?
    What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
    • HMF22112's avatar
      HMF22112
      The modem is an Arris DG2480.
      We have 400 mbps internet service.
      We got the NETGEAR - Orbi AC2200 Tri-Band Mesh Wi-Fi System (3-pack). One satellite gets a 5.0 channel, but the other one of the satellites keeps defaulting to the 2.4 channel. Any way to fix this? One gets approx 280mbps, the other around 75mbps.
      Each satellite is about 40-45 feet from the main Orbi. Our home is a two-story, 3600 sq ft.
      • CrimpOn's avatar
        CrimpOn
        What happens if you swap the two satellites? (exchange locations) Radio connects in a straight line. Perhaps there is too much immaterial n the direct path for the 5G signal to penetrate.
