VHM
Jun 20, 2019Aspirant
ORBI AC2200 AP mode
HI, I am using ORBI AC2200. When i configured as AP mode at the master router, can I use the "internet" port as one of the L2 ports to connect upstream? Somehow it works but its not stable. The Wifi...
- Jun 21, 2019thanks. i try again this evening and it works fine with the internet port as l2 uplink now. the wifi is stable. Thanks all
CrimpOn
Jun 20, 2019Guru - Experienced User
I believe the Orbi is intended to connect using the WAN (Internet) port, but that it may function in AP mode using any of the LAN ports.
The "ring light" on the Orbi is supposed to be OFF when it is working correctly.
Here's a link to what the LED on the back and the ring light at the top indicates:
https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-mean
Maybe the light being on is a function of not being connected using the WAN port?
VHM
hi. thanks
so what I would like to find out is that if i can use the internet port as uplink if i use ap mode. as when i used that my wifi conection is not stable. i wonder if that is my orbi problem or officially netgear is not suggesting to connect that way. as if i can use that officially means i hv one more ethernet port
yes the light ring will be off if sth is connected. if i cannot use the internet port i will simply plug a loopback there to get rid of light. thanks
